MicroSD card keeps 'ejecting'
  • 535
  • phirephoto's Avatar
    Hello All,
    I have a Legion Go (obviously lol) and the micro sd card keeps 'ejecting'. So it's not ejecting as if I pressed it - like if I were to press it, it would 'spring' out, it just is ejected slightly enough to not be read by the device. I have EmulationStation launch at startup, and every so often it fails to launch. I look and the SD card has ever so slightly popped out. I have to press it down to release it, then push it back in. Happened with 2 different cards.
    Anyone else seeing this?
  • NayNay's Avatar
    Level 26
    Hi @phirephoto Troubleshoot device, reboot, check if device software is up -to-date/latest software is installed. Could also be SD card itself, I know you said you have tried a different card, maybe format DS card, create new partition. But first check basics such as device drivers and software is updated. Some suggestions you could try.
    //impermanence.
    Disconnect to reconnect
  • NayNay's Avatar
    Level 26
    Oh and unmount/disconnect external devices/stora6ge when troubleshooting.
    FYI: regarding software updates it has latest security patches which fix bugs (bug fixes) there might've been in previous software patches, etc. Often times issues stems from software updates or rather the device software not being updated.
    //impermanence.
