Legion GO - Help with AMD drivers
  • 1
    Reply
  • 3069
  • sueta13's Avatar
    Hello everyone,
    I recently received my Legion Go and tried to install the AMD drivers using the Adrenaline Software. First I tried to use the general Adrenaline Software install (not device-specific) but it did not work, tried multiple times, and it just ended up with the Adrenaline Software and an error when opening or not installing it at all.
    After that, I ran the DDU AMD tool for deleting drivers, and I tried this tutorial and this one (installing the specific driver for the APU via the device manager and then installing Adrenaline Software separately).
    There was a strange thing at first contrary to the tutorial I did not have the AMD Radeon Graphics on the Device Manager when I clicked it showed an error saying: of Unknown devices, with a warning signal (missing driver) a Multimedia device and therefore I thought it could be the GPU so I installed the drivers on this one.
    After installing both the driver and the Adrenaline Software, I saw that it did install some app called AMD Radeon Settings which when I click it shows an error saying: Radeon settings are currently not available. Please try again after connecting the AMD graphics. But the Adrenaline Software is still missing.
    I don't know what else I can try.
    Please could you give any advice or any information to point me in the right direction?
    Thank you in advance.
  • SKYTRiXSHA's Avatar
    Hey @sueta13
    Could you DDU the drivers away and download the official drivers from the Lenovo website? That helped me when I had this same issue.
    You need to use the purely device-specific drivers for the Lenovo Go!
    Otherwise, it does not work; you can try to do the same trick as you can do on ASUS handheld, aka download 780M drivers (but don't touch any tuning settings that will brick the drivers).
    Let me know if DDU + installing the latest drivers from here will help you.
