temperature
  • 8
  • 5915
  • PierBob's Avatar
    Hello everyone for some time the temperatures of my pc, lenovo legion rayzen 7 , 4800H and rtx 2060, has raised its temperatures . Today through a video on youtube I discovered that there is this legionfancontrol app where you can manage your fans. The problem is that when I try to use it gives me this error :Cannot write to a closed TextWriter. Object name : "StreamWriter". Has anyone already encountered these problems and can they help me?
  • 8 Replies
  • Nouhaila4's Avatar
    Level 12
    try giving it breathing space under the fans it should drop temperature
  • esraaali's Avatar
    Try to communicate with them
  • PierBob's Avatar
    @Nouhaila4 hello thanks for your replies I have another problem my cpu in game has reached 105 degrees causing it to lower the frame, I noticed that the clocks are always at the maximum, but if I open the task manager I don't notice any program that uses it actually 100%, how could I fix this situation?
  • mostak's Avatar
    Level 15
    @PierBob 105 degrees !! are you kidding me, no, this is a very dangerous temperature for the graphics card, and it may harm it in the long run and destroy it, and you will need to replace it. Do not let your device reach that level of heat again, why not try to take it to be examined by a hardware repair specialist
  • PierBob's Avatar
    @mostak thanks for rep , not gpu but cpu , Now I changed from energy saving the max usage when it is connected to the current, it went from 100 to 90 and the clock frenquence has dropped to 1700 unlike before which was always on 4300 and together with it has also dropped the temperature from 80 degrees at rest to 50, although they are still several but there are 45 degrees outside
  • mostak's Avatar
    Level 15
    @PierBob Very good👏, I still see that you take it to a specialist, but because I am interested in following up on hardware malfunctions, so I will search for you myself for a solution to your problems, and if I find it, I will come back and tell you 😊
  • PierBob's Avatar
    @mostak yes please , thank u
    @mostak has not changed mate, I tried to start the game and the CPU continues to overheat and I have frame drops because it goes into protection
    I suspect the computer needs some good cleanup. When the fans and air vents have dust stuck in them, the head cannot get away from the CPU/GPU quickly enough. It's very simple to do a basic cleaning of a Legion laptop, but if you are not confident in doing so yourself, you should find a workshop that offers these services. Every laptop is going to accumulate dust over time and require some blowing out at some point.
